K1200S new airbox?
K1200S new airbox?
Beitragvon CorvetteC6 » 09.04.2008, 16:53
Does anyone know for sure if there is a new airbox (13717705465) on the market? I´ve gotten no respons here in my country so I am now looking abroad for my self. Do you have a tip on a webshop or similar? What is the price in Germany?
CorvetteC6
Beitragvon Croissant » 09.04.2008, 18:02
Hi Corvette,
......It's a nice car, indeed
welcome in the "old Europe"...... :lol:
greetings from southern Germany
Klaus
laissez faire, laissez aller
Croissant
Wohnort: 76571 Gaggenau (Baden) E 8°18'38'' N 48°48'42''
Motorrad: K 1300S (2011)
Beitragvon RHEINPFEIL » 10.04.2008, 07:02
There were Informations about a new Airbox with a new Idle Controller, last year. But I didn´t follow the Problem due to winter break. My last informations were that the box wasn´t available before Winter.
Reason for the change were problems with the idle valve which hung up at 2000 sometimes and idle came down very slowly which isn´t much fun, when you ride in the alps. The changes in the construction have been made only to solve this problem, it doesnt provide more power if this is, what you are looking for.
When the problem first came up, the dealer remapped the bikes software, this solved the problem for 90% and it occoured only single times that the idle hung up. For example, at a stop after top speed autobahn rides :D
I´ve locked out the throttle valve stop and built in a lambda sond eliminator whithout problems at the moment. The idle problem only occurs when the engine is hot and airtemperature is at 20 degrees C +, in Germany the Temperatures are half about that, at the moment. :cry:
Viele Grüße aus Köln
René
RHEINPFEIL
Motorrad: MBSLK
Beitragvon kivo » 12.04.2008, 10:36
Also, alles hab ich nicht verstanden, kann aber behaupten, Probleme mit der Airbox gehabt zu haben (bzw, habe ich noch :evil: ) und habe von BMW bereits die Zusage, eine andere (also neu entwickelte) Airbox zu bekommen.
(100% Kulanz bei Bj 2005 und Garantieverlängerung)
Harzlich
Kivo
Danny Kaye
kivo
Beitragvon Detlef » 12.04.2008, 12:11
und wie äußern sich diese Probleme , kivo?
Detlef
Beitragvon RHEINPFEIL » 12.04.2008, 16:48
Denke mal entweder bleibts Gas bei 2000 hängen, d.h. kaum Motorbremse oder geht im Stand aus.
Ich könnte mir vorstellen, das der Lufttemperatursensor so ungünstig angebracht ist, dass er sich unter bestimmten Betriebszuständen durch die Abwärme des Motors so aufheizen kann, dass hierdurch verfälschte Werte entstehen die die Einspritzanlage so beeinflussen dass vorgenannte Probleme entstehen. Bei der Hayabusa konnte man das mit Alufolie isolieren. Hab ich dummerweise nicht dran gedacht als die Kiste aufgedeckelt war. Muss ich mal nachholen vielleicht hilft es ja.
René
RHEINPFEIL
Motorrad: MBSLK
Beitragvon kivo » 13.04.2008, 15:53
Detlef hat geschrieben:und wie äußern sich diese Probleme , kivo?
@Detlef,
also, wenn ich jetzt Du wäre, würde sowas wie "schonmal die Suchfunktion genutzt" oder so kommen :lol: :wink:
ja nee, iss klar, wenn die Karre richtig gescheucht wird und der Motor richtig heiß ist, geht der Bock beim Gas wegnehmen, z.B. beim Runterschalten aus :shock: Danach lässt sie sich nur shr schwer starten und schüttelt sich, wie ein Boxermotor, läuft irgendwie unrund. Nach einigen Hundert Metern fährt sie dann wieder ganz normal...bis zum nächsten Kreisverkehr oder nächsten Ampel :roll:
Lässt man´s langsamer angehen, ist alles ganz normal...
Hab das Problem jetzt seit August 07, BMW hatte aber die Airbox bisher noch nicht in überarbeiteter Ausführung. Ich habe aber im März Bescheid bekommen, dass die "Neue" inzwischen lieferbar ist und ich zum Tausch kommen kann. Dabei wird auch eine neue Software aufgespielt. Bin bloß noch nicht zum :) gekommen, Pisswetter und 120 km Anfahrt nach Erfurt haben´s mir "verhagelt"
.. weisse Bescheid :wink:
Horst Schlämmer
Harzlich
Kivo
Danny Kaye
kivo
Beitragvon RHEINPFEIL » 13.04.2008, 17:52
Also nach dem Softwareupdate letzten Juni ist sie zumindest nicht mehr ausgegangen.....
Airboxwechsel hätte ich evtl. selbst zahlen müssen, wegen dem 2. Luftfilter
:roll: das is ja nicht mehr Orschinool
Daher hat der :D erst mal nur die SW geändert. Ob bei der Inspektion im Oktober noch mal ein Update erfolgte, habe ich vergessen zu fragen.
René
RHEINPFEIL
Motorrad: MBSLK
Re: K1200S new airbox?
Beitragvon Retep » 22.05.2008, 16:48
CorvetteC6 hat geschrieben:Does anyone know for sure if there is a new airbox (13717705465) on the market? I´ve gotten no respons here in my country so I am now looking abroad for my self. Do you have a tip on a webshop or similar? What is the price in Germany?
Recently my dealer changed my airbox as well, since it happened to me once or twice that the rpm's seemed to be stuck at about 2500, while not applying the throttle at all.
According to the dealer I was the 4th or 5th person who encountered this problem . :?
Bike had 4300 km when they changed it. Since then I rode 2100 km and everything seems to work fine. Not sure if they did something on the SW / mapping.
2006 S Gelb/schwarzes Bienchen mit allem drum und dran (ausser Board computer)
Retep
Beitragvon RHEINPFEIL » 22.05.2008, 19:17
Meine Wunschliste für Montag :D
Neue Airbox mit Leerlaufsteller
Neue Software oder neues Steuergerät
Neue Kupplung für den Kraftstoffschlauch
Neue Kugelköpfe für den Duolever
Das wars erst mal.....
René
RHEINPFEIL
Motorrad: MBSLK
Beitragvon minolta73 » 11.06.2008, 10:22
Also ich habe meine ja erst seit einigen Wochen...
Woran erkennt man, dass bereits die neue Airbox montiert ist?
minolta73
Beitragvon Vessi » 08.06.2009, 08:50
nu' ist'se auch kaputt, mein mopped,
das gas bleibt mehrere sekunden hängen,
nervt beim schalten, nervt ganz besonders,
wenn man auf kurven zugeflogen kommt,
das hat sich schon über einen längeren zeitraum angekündigt,
war aber immer noch gut fahrbar
alles soweit telefonisch geklärt mit hakvoortchen's gerd,
kulanzantrag ist gestellt, mopped wird demnächst abgeholt,
super service... :!:
Air Box
Beitragvon yellowk12s » 09.06.2009, 19:35
Moin Moin,
ich habe heute meine Maschine vom freundlichen abgeholt. Es wurde auf Kulanz eine neue Air-Box verbaut, da bei mir das Problem auftrat, dass an der Ampel der Motor abstarb. Da ich noch gut einen Monat Mängelverjährungsfrist habe, musste der Freundliche die Box tauschen.
Gruß yellowk12s.
yellowk12s
