Einsteiger
Re: Einsteiger
Beitragvon Mohikaner76 » 14.10.2011, 12:07
A propos Insekten:
Mythbusters: Episode 156 - Bug Special
A person riding a motorcycle at high speed can be killed from the impact of hitting a bug.
plausible
Doing some research, the Build Team discovered that the most vulnerable point on the human body was the throat; an impact with 76 pounds of force could cause the windpipe to swell and suffocate the victim. They attached a force plate to a mannequin torso, put it in a sidecar attached to a motorcycle, and had Tory drive at 85 miles per hour so that the plate would hit an insect suspended at throat height. Tests with a common fly, a cicada, and a Goliath beetle (the largest flying insect they could find) yielded 10, 37, and 100 pounds of force, respectively.
To investigate the speeds needed to inflict a lethal injury at head or chest height, the team set up an air cannon to fire a Goliath beetle analog at the force plate. An impact at 120 mph gave 285 pounds of force, while a test at 200 mph (described as the speed of the fastest motorcyclist ever to get a traffic ticket) yielded 500 pounds. Although neither of these was high enough to result in a fatal injury, the team deemed the myth plausible, since a heavy enough insect hitting just the right spot on a rider could lead to his death.
Quelle: http://mythbustersresults.com/bug-special
Ein Argument für Verkleidung?
Gruß Marc
K1200R
6,5L/100Km
Mohikaner76
Re: Einsteiger
Beitragvon Brocki » 14.10.2011, 12:10
Mohikaner76 hat geschrieben:Meine Kombi hab ich noch nie geputzt.
Ferkel :shock:
Gruß Brocki
Brocki
Re: Einsteiger
Beitragvon Mohikaner76 » 14.10.2011, 12:11
Brocki hat geschrieben:
Ferkel :shock:
Das sieht viel brutaler aus so :twisted:
Gruß Marc
K1200R
6,5L/100Km
Mohikaner76
