LED Scheinwerfer
Re: LED Scheinwerfer
Beitragvon geeza1969 » 03.07.2020, 10:45
K1300R - to work out bracket size and hole positions I first checked the bike was level side to side then used the laser level to check the position of the front headlight mounts relative to each other and to the front frame.
Next set up the headlight on the bench and levelled it using the top straight section of the casting for reference. New light is 4mm wider than original and on this light the clutch side mount is 7mm higher than the throttle side.
Roughed out some brackets in 6mm aluminium.
Trimmed the plastic rear cover on the throttle side - cut-out was made to allow the light to sit lower without interference with the bike mounting point.
Used a 19mm hole saw and a guide bracket on the clutch side - cutout was made to allow the light to sit further back against the front of the bike mounting point.
Picture of headlight after final adjustment.
Now making up a bracket to connect to the rear supports, will post pictures as I progress.
winkG
geeza1969
Beitragvon geeza1969 » 06.07.2020, 13:07
For reference - K1300 R headlight adjustment instructions - may be helpful when setting up the led light or just adjusting your orginal headlight.
headlight adjustment.pdf
(159.34 KiB) 842-mal heruntergeladen
geeza1969
Beitragvon OldHolborn » 11.07.2020, 19:26
Ich hab heute einen LED Scheinwerfer an die F800r angebaut. Völlig problemlos, alten Scheinwerfer runter, an den neuen Stecker dran, festschrauben, fertig. Sogar der 2 mal 6 Sekunden Griff funktioniert einwandfrei. Nu werd ich mich mal als Nächstes an meine Dicke machen winkG
OldHolborn
Motorrad: K1300r Bj.2009
Beitragvon 40er » 21.07.2020, 12:03
geeza1969 hat geschrieben:For reference - K1300 R headlight adjustment instructions - may be helpful when setting up the led light or just adjusting your orginal headlight.
Hi Geeza1969, many thanks for your support :-) My project starts the next weeks :D
40er
Beitragvon Herberti » 29.08.2020, 18:04
Hallo Freunde des hellen Lichts,
auch ich habe den LED-SW an meiner K1200R verbaut. Alles funktioniert tadellos, das Licht ist einfach Klasse.
Nun hätte ich noch eine Frage bezüglich des TFL der ja bei Abblend- und Volllicht immer mit brennt, wie auch das Rücklicht.
Hat schon einer eine Lösung gefunden dies zu umgehen (so schwierig sollte das ja nicht sein) bzw hat schon einer Ärger deswegen mit der Staatsgewalt bekommen?
Bin sehr gespannt auf eure Antworten... bis die Tage !
Herberti
Motorrad: K12R
Beitragvon Rudi79 » 30.08.2020, 16:11
Kannst ja jedes beliebige SW Kabel per Schalter trennen.
Wenn du dann kein „LampF“ im Tacho haben willst, musst du dann mit einem Widerstand arbeiten.
Rudi79
Beitragvon OldHolborn » 01.09.2020, 13:21
Ich hab mal eine Frage zum Massekabel vom Standlicht vom Original Scheinwerfer. Wo habt Ihr die Masse vom Standlicht mit aufgelegt? Der Led Scheinwerfer hat ja am Standlicht nur einen Plus Ausgang. Ich hab es erstmal weggelassen, aber sobald ich auf das Hufeisen um schalte, bekomme Ich die Lampf Meldung.
Ich habe den Led Scheinwerfer genommen in der Original Optik. Also den wo unten ein kleines Standlicht wie beim Original drin ist. Ablendlicht habe ich vom Led zweimal aufgeklemmt.
OldHolborn
Beitragvon geeza1969 » 14.09.2020, 09:48
After a very long wait the plug for the headlight arrived. Rectangular bracket on the right is for the headlight adjustment. Bracket in the middle holds plug in place and is a mount for the instrument cluster loom clip.
Will hopefully get it fitted tomorrow scratch
geeza1969
Beitragvon geeza1969 » 17.09.2020, 06:13
Finished :-) very long wait for plug due to COVID!
geeza1969
Beitragvon gTa9000 » 19.09.2020, 10:48
Absolutely stunning @geeza1969 !! Very nice work.
Belgischer 2011 K1300R (acid green metallic, full option, Akrapovic, Metzeler Roadtec 01)
gTa9000
Motorrad: 2011 K1300R
Beitragvon gTa9000 » 19.09.2020, 11:06
Hallo Allen,
(Bin Belgier - mein Deutsch ist nicht ganz korrekt - bitte verzeih'mir also welche Schreibfehler - danke!)
Ich bin bereits 2 Jahre sehr froh das es eine modern aussehende Lösung gibt fürs Licht auf unsere K-R. Allerdings hab'Ich keine Erfahrungen mit Metallwerke oder Elektro (Kabel/Stecker). Bis jetzt hätte Ich also recht Angst von welche Installation, z.B. den Originalkabelbaum will Ich absolut nicht ändern.
Dieser Thread ist frisch und Ich hab'dieser also einige Mal gut durchgelesen.
Jetzt bin Ich -glaub'Ich- fast da mit dem Kopf wie es alles sein muß/kann.
Weil auf Deutsch, sind manchmal einige Details vielleicht noch nicht gans klar für mich, daher:
--> Darf Ich nochmal rekapitulieren bitte und korrigieren Sie mir bitte wenn Ich es immer noch falsch vor hab? Danke!
Installation von aftermarket K50 LED-Licht auf K1300R mit orig.Lampenverkleidung und 2-Stecker-Lösung:
(1) Ankauf K50 LED-Scheinwerfer auf eBay u.A. - diverse Links hier in der Thread
(2) Ankauf 2 Stecker wie von Rudi79 beschrieben auf p.2 dieser Thread
(3) Originalstecker von K50-LED-Scheinwerfer abschneiden und die 2 neue Stecker anbinden wie von Rudi79 beschrieben
(4) hintere K50LED-Scheinwerferverkleidung abschrauben (und nicht verwenden)
(5) LED-Licht paßt so ins Motorrad ohne Schneiden/Dremeln/..., mit original K13R Lampenverkleidung drauf?
Fragen dabei:
[F1] Muß der Ölkühler dann immer noch einige cm runter?
[F2] Gibt es Bilder vom K50 LED Scheinwerfer an K1300R ohne Brackets die weiter hinten und höher positionieren?
Ich habe @geeza1969 via Facebook um die exakte Mäße von seine Brackets gefragt. Hoffenrlich hat er diese und kann'Ich jemand hier in die Nähe die herstellen lassen :)
Gibt es noch Sachen die Ich vergessen habe?
Herzlichen Dank!!
gTa9000
Beitragvon geeza1969 » 20.09.2020, 11:19
Installation of aftermarket K50 LED light on K1300R with original lamp cover and 2-connector solution :
(1) Purchase of K50 LED headlights on eBay and others - various links here in the thread Correct
(2) Purchase of 2 connectors as described by Rudi79 on p .2 this thread Correct
(3) cut off the original connector from the K50 LED headlight and connect the 2 new connectors as described by Rudi79 Correct
(4) unscrew the rear K50LED headlight cover (and do not use it)
Two ways to mount the headlight - Rudi method - take off the rear cover and use a piece of flat bar to mount the light.
The other is to leave the rear cover on and use the side bracket method
(5) the LED light fits into the motorcycle without cutting / Dremeln / ..., with original K13R lamp cover on it? Correct the headlight shroud remains in place and does not need modification.
Questions:
[F1] Does the oil cooler still have to go down a few cm? No need to move the oil cooler
[F2] Are there pictures of the K50 LED headlights on the K1300R without brackets that are positioned further back and higher? Not that I have seen, if you use Rudi method you can mount the light further back and up but cannot refit the K1300 headlight shroud
Hope this helps.
geeza1969
Beitragvon gTa9000 » 20.09.2020, 16:43
geeza1969 hat geschrieben:Installation of aftermarket K50 LED light on K1300R with original lamp cover and 2-connector solution :
Questions:
Hope this helps.
clap
gTa9000
Beitragvon Das O » 23.10.2020, 22:30
thx 4 sharing
Das O
Motorrad: K100RS, K13R, PX220
