Die Lösung für Windschutz
Re: Die Lösung für Windschutz
Beitragvon KDouze » 13.06.2010, 17:24
Hat schon jemand dieses Windschild getestet? Das Loch unten soll die Sogwirkung / den Winddruck von hinten ("back pressure") verringern. :idea:
http://shop.heroblobs.co.uk/collections/bmw-k1200gt/products/calsci-screens-for-bmw-k1200gt
Nearly all of our windshields have vents. These vents are part of the aerodynamic design of the shield, to reduce turbulence and noise. They are not there to make a flow of air on the rider. When you’re riding on the highway, any windshield is pushing air away from the rider. This leaves a low-pressure pocket between the windshield and the rider. The air flowing past the motorcycle wants to drop into this low pressure area. If the outside air is allowed to spill into the area between the windshield and the rider, the result is turbulence, noise, and drafts. When outside air spills into the rider area, it almost always falls in a curved path, causing spinning vortices of air. These vortices are noisy and can cause the battering and hammering on your helmet reported by some riders. Our windshields and vents are designed to funnel air into the rider region to relieve this low pressure area and greatly reduce the tendency of outside air to spill in. The vents are designed so that the air coming through them is quickly dispersed, leaving almost no detectable air flow at the rider. Our goal is to produce almost completely still air on the rider with no back pressure.
Zuletzt geändert von KDouze am 13.06.2010, 17:37, insgesamt 1-mal geändert.
KDouze
Wohnort: Saint-Priest-en-Jarez (bei Saint-Etienne / Frankreich)
Beitragvon KDouze » 13.06.2010, 17:34
meine zweite Frage wäre: kann man so ein Loch und die Einkerbung unten evtl. nachträgich schneiden lassen, ohne die Stabilität der Scheibe (ich habe die hohe Wunderlichscheibe) gefährlich zu verringern :? ?
Ich finde übrigens die oben zitierte Erklärung total plausibel und die angebotene Lösung erfolgsversprechend.
KDouze
Beitragvon Repa » 13.06.2010, 17:57
Ich habe den Laminar lip in meine K1200S eingebaut um zu Testen wie der funktioniert.
Ich habe den nur in Finnland getested, d.H. max 120 km/h.
Meine Grösse: 183 cm.
Gut: gutes Schutz gegen Wind. Kein wirbel, kein Windlärm. Wind gehr über Schulterbereich. Sehr positiv. Und einfache Montage dazu.
Negativ: sieht echt hässlich aus.
Trotz viele positive Sachen werde ich den nur wegen Aussehen ausbauen.
Grüss
Repa
Repa
Beitragvon gumby » 14.06.2010, 01:24
Repa hat geschrieben:Trotz viele positive Sachen werde ich den nur wegen Aussehen ausbauen.
du hast mein vollstes verständnis. ;)
2nd edit:
... und wenn du schon dabei bist: bau doch bitte direkt dieses grottenhässliche topcase ebenso ab. ;) das paßt irgendwie so gar nicht zur "s".
Repa hat geschrieben:Grüss
Repa
gumby
Beitragvon Repa » 14.06.2010, 08:37
gumby hat geschrieben:
2nd edit:
Da hast du auch recht. Passt auch nicht.
Es ist mit Schnellverbindung befestigt so ausbauen ist einfach. Normaleweise fahre ich doch ohne den und auch ohne sportkoffer.
Sieht viel besser aus.
Repa
Repa
Beitragvon gumby » 15.06.2010, 00:45
Repa hat geschrieben:Da hast du auch recht. Passt auch nicht.
nicht wirklich. aber ich hab' eh 'ne aversion gegen topcases ...
Repa hat geschrieben:Es ist mit Schnellverbindung befestigt so ausbauen ist einfach. Normaleweise fahre ich doch ohne den und auch ohne sportkoffer.
... wohingegen koffer schon sinn machen können. wässerchen, legale drogen, abe & co für die streckenwartung ... ;)
und die sportkoffer stören nicht gar so sehr die optik, finde ich jedenfalls. nur die lackierung beißt sich mit der biene. ;)
Repa hat geschrieben:Gruss
Repa
gumby
Beitragvon Repa » 15.06.2010, 08:21
Dabei bin ich nicht in der gleiche Meinung. Geschmacksache.
Vielleich sollte man die Sportkoffer gelb mit schwartze Streifen lackieren :)
Grüss
Repa
Repa
Beitragvon gumby » 15.06.2010, 21:48
gumby hat geschrieben:und die sportkoffer stören nicht gar so sehr die optik, finde ich jedenfalls. nur die lackierung beißt sich mit der biene. ;)
und das ist auch gut so. ;)
Repa hat geschrieben:Vielleich sollte man die Sportkoffer gelb mit schwartze Streifen lackieren :)
ich glaube es würde schon reichen, wenn die graue pelle zwischen den schwarzen streben die farbe wechseln würde.
hab letztens beim händler 'ne biene mit silbernem tank gesehen. geht ja gar nicht. :roll:
Repa
gumby
Beitragvon schubbler » 27.09.2010, 19:00
Andi#87 hat geschrieben:... wesentlich höheres Backpressure.
Schön ist, das die Wunderlich Scheibe so stabil ist....
Yepp, kann ich insoweit ebenfalls bestätigen. Aber der Unterdruck hinter der Scheibe fällt auf 0, wenn die Side-Flaps montiert sind.
Die Geräusche sind bei mir (193 cm/BMW-Systemhelm 6) im Vergleich zur hohen Originalscheibe absolut im grünen Bereich - aber das ist mein subjektives Empfinden.
:wink:
schubbler
Motorrad: K 1300 GT
