ZUMO Ver.3.00 erschienen
Beitragvon stone » 21.02.2007, 20:24
Frisch im Comkor-Forum gefunden.....
ZUMO V3.00 zum download verfügbar.
Das Ganze sollte man noch mit Vorsicht behandeln,da wohl einige Leute hinterher mit Abstürzen Probleme haben.Aber es ist ja wie immer das sich nur Leute melden bei denen etwas nicht funktioniert,der Rest schweigt weil es klappt.
Changes made from version 2.50 to 3.00:
* Allow panning from main map. Touching vehicle on main map displays coordinates and elevation in save dialog.
* Added more fields to the trip computer including fuel gauge odometer.
* Enabled compass display full time with additional data fields.
* Enhanced XM weather support which is available from XM button on the main menu.
* Enhanced traffic incident reporting.
* Added support for SDHC cards and increased MP3 playlist limit to 1000 songs.
* Added Audible books support.
* Added option to limit BT headset audio to phone only.
* Added option to display track log on map.
* Added track log archive function.
* Modified import /share pictures to work directly from jpeg viewer without the checklist.
* Added support for the modified drawing styles present in certain specialty maps.
* Display unpaved roads differently than alleys, expanded zoom level where favorites are displayed.
* Disables auto-zoom operation when off-road.
* Added ability to treat certain route vias as shaping points which will not be flagged or announced. Qualified shaping points are Intersections and points on roads which are not addresses, such as I-35N or HwyA. Requires routes to be created with MapSource 6.12.1 or using the zumo route planner.
* Enhanced off-route recalculation for mixed on/off road routes and routes with shaping points.
* Added support for new Pre-Recorded voices for Brazil, Bulgaria, Lithuania, Romania, Serbia.
* Updated US/Canada Daylight Saving time support.
* Correct shutdown when enter more than 4 vias.
* Correct issue preventing conversion of tracks to routes in southern hemisphere.
* Correct issue which prevented writing recent tracks to the GPX file.
* Correct issue which prevented finding points of interest after search where city was spelled.
* Correct issue which prevented finding some addresses with overlapping maps.
* Correct issue where a truncated route could contain an erroneous point.
* Correct issue where a truncated route could be stopped incorrectly.
* Correct behavior when two Cyclops safety cameras are in range.
* Correct handling of track to route conversions that are completely off road.
* Correct issues with simulator going off route.
stone
Zurück zu Navigation - Gps
