Neue BMW Motorrad Navigator III+ software version 4.40
Beitragvon Handyman » 29.11.2007, 08:58
http://www.naviboard.de/vb/showthread.php?p=178669#post178669
http://www8.garmin.com/support/agree.jsp?id=3653
BMW Motorrad Navigator III plus software version 4.40 as of November 21, 2007 - Source: Garmin-Website
Download [4.82 MB]
View download instructions and system requirements
Notes:
If after updating your system software your GPS displays 'Incompatible Audio Version', please update your voice software using this link.
Reverting to previous software revisions will clear all user data.
Change History
Changes made from version 4.30 to 4.40:
Corrected issue with dialing phone numbers with some phones.
Allowed greater space for Detail map names to be displayed.
Corrected rare occurrence of long satellite acquisition time.
Corrected issue with closed entry ramp traffic event avoidance.
Added Autobahn avoidance setting.
Corrected issue with transferring routes containing GPI points.
Other minor corrections and improvements.
Changes made from version 4.20 to 4.30:
Fixed shutdown when traffic receiver is plugged in and the On Current Route option is selected under Tools->Traffic Info->Near.
Fixed inability to change Routing Preference to 'Shorter Distance'.
Corrected issue where incorrect character representing meters was displayed in Active Track Log settings when using distance resolution setting.
Changes made from version 4.10 to 4.20:
Instructions for using this software
It is recommended that you disable screen savers or other programs running on your PC while you go through the update process. Disruptions to the update process may render your GPS inoperable. If the transfer is interrupted, turn off the GPS and then turn it back on. Reboot your PC, go to step #5 and attempt the download again. GARMIN is not responsible for failed downloads of operating software to the GPS and factory resetting the GPS unit will fall under our Flat Rate Repair Policy.
Power your GPS using the power adapter that came with your device. Next, connect your GPS to your computer using a GARMIN PC Interface cable to an open USB port. Turn the GPS on.
If a program called gStart launches during this update, please ignore it. gStart is not required to complete this update process.
If your computer asks for a driver, you need to install the Garmin USB driver. Please see the software and installation instructions that came with your device, or download and install the USB driver from Garmin's website.
Click on 'Download' at the top of this web page, and choose to run the file on your computer. Select Run.
Select OK, then select Setup.
System requirements
IBM-compatible PC running Windows 2000 or Windows XP operating system and an available USB port.
Habe die neue firmware/software ohne Probleme installiert.
Autobahnen können jetzt ausgeschlossen werden!
Wichtig: Mache einen backup von deine eigene Routes, Waypoints u.s.w. den nach den Update is das Navi wieder im ersten Neuzustand, auch deutsche Sprache, motorrad, lautstarke, u.s.w. müssen neu eingestellt wern. Geht aber recht schnell, wenn man alles ruhig abarbeitet.
Zum schluss muss auch das BlueTooth-telefon und bei mir auch noch das BlueTooth-Dongle von Autocom, angemelded werden.
Auch das ging prima.
Danach sieht man diese Info am Navibildschirm:
m.fr.Grüssen, The Handyman
Handyman
Zurück zu Navigation - Gps
