Zumo Update
Zumo Update
Beitragvon bernile » 21.12.2007, 23:22
Hallo seit 20.12.2007 gibt es eine neue Software Version 3.80
Änderungen auf der Garmin Seite
http://www8.garmin.com/support/blosp.jsp
oder einfach der WebUpdater.
Bernhard
bernile
Motorrad: abc
Re: Zumo Update
Beitragvon Georg » 22.12.2007, 00:08
Danke, werde ich morgen mal testen.
Weißt du Genaueres über die Änderungen?
Beitragvon Heinz » 22.12.2007, 00:15
...zu Diensten.
Change History:
Changes made from version 3.30 to 3.80:
Add support for African Time zones.
Add support for several new pre-recorded voices.
Add support for distances in yards when a British voice is selected (may require updated voice).
Added support for MAD Maps scenic routes.
Allow the compass page to display 5 digits of elevation.
Improved handling of circular routes. Allows entry at alternate point. Will not announce arrival when starting a route. (All routes will be deleted after update, but can be re-imported from GPX files.)
Keep the map detail level when go from main map to browse map.
When reviewing a gas station after pressing the fuel button from main map, the map will now be centered on selected gas station rather than the vehicle.
Change Optimal Reorder so it does not include the final point when reordering.
Correct issue where backlight may change if you remain on the backlight adjust page for a period of time.
Correct issue where backlight may turn off when location is above polar circle.
Correct issue that would sometimes cause highways to be labeled with the incorrect name.
Correct issue that would not allow more than a single point to be added to some routes.
Correct issues when the same map is loaded in two different regions.
Correct issue when searching for cities on basemap.
Correct off road transitions in track to route when there is no map coverage.
Correct issue playing Audible format 4 books.
Correct distance for mixed routes imported from MapSource
Correct issue that caused all traffic delays to be 1min when using certain maps.
Correct issue that prevented TrafficMaster service from being properly named on the unit.
Correct issue that prevented some very large track log activities from being archived correctly.
Correct issue where changes to a route would be lost if you press and hold the back button.
Correct issue that caused MP3's to be paused for navigation announcements when navigation was set to off and a pre-recorded voice was selected.
Beitragvon Detlef » 22.12.2007, 00:15
Correct issue that caused MP3?s to be paused for navigation announcements when navigation was set to off and a pre-recorded voice was selected. ´
Changes made from version 3.20 to 3.30:
Added a user selectable Off Route Recalculation Mode
Updated Compass and Trip Computer displays to remember their last page mode
Enabled Bluetooth troubleshooting whenever a phone is paired
Allow volume adjustment when using a Bluetooth headset with audio option set to phone only
Added Lithuanian text language support
Corrected issues in Trip log archive support that resulted in 0 length files and false reporting of full logs
Corrected issue on Compass page that prevented it from displaying the heading
Corrected flashing on the Enter Coordinates page
Corrected issue that allowed the page key to escape from the pin entry for Garmin Lock
Corrected rare issue that could prevent proper startup when custom POI files contain a large number of bitmaps
Corrected problem ejecting on Mac computers
Changes made from version 3.10 to 3.20:
Add support for coordinate entry in alternative grid formats
Maintain zoom level when panning from main map
Correct Extended Postal Code searching error in the UK
Correct shutdown when import waypoint with unsupported symbol
Correct import of certain route points with MapSource 6.12.2
Correct issue that prevented trip log archive function from activating
Changes made from version 3.00 to 3.10:
Corrected unit shutdown related to map drawing.
Corrected position of the traffic alert button on main map.
Pause trip computer time update in charge mode (automotive mount).
Changes made from version 2.50 to 3.00:
Allow panning from main map. Touching vehicle on main map displays coordinates and elevation in save dialog.
Added more fields to the trip computer including fuel gauge odometer.
Enabled compass display full time with additional data fields.
Enhanced XM weather support which is available from XM button on the main menu.
Enhanced traffic incident reporting.
Added support for SDHC cards and increased MP3 playlist limit to 1000 songs.
Added Audible books support.
Added option to limit BT headset audio to phone only.
Added option to display track log on map.
Added track log archive function.
Modified import /share pictures to work directly from jpeg viewer without the checklist.
Added support for the modified drawing styles present in certain specialty maps.
Display unpaved roads differently than alleys, expanded zoom level where favorites are displayed.
Disables auto-zoom operation when off-road.
Added ability to treat certain route vias as shaping points which will not be flagged or announced. Qualified shaping points are Intersections and points on roads which are not addresses, such as I-35N or HwyA. Requires routes to be created with MapSource 6.12.1 or using the zumo route planner.
Enhanced off-route recalculation for mixed on/off road routes and routes with shaping points.
Added support for new Pre-Recorded voices for Brazil, Bulgaria, Lithuania, Romania, Serbia.
Updated US/Canada Daylight Saving time support.
Correct shutdown when enter more than 4 vias.
Correct issue preventing conversion of tracks to routes in southern hemisphere.
Correct issue which prevented writing recent tracks to the GPX file.
Correct issue which prevented finding points of interest after search where city was spelled.
Correct issue which prevented finding some addresses with overlapping maps.
Correct issue where a truncated route could contain an erroneous point.
Correct issue where a truncated route could be stopped incorrectly.
Correct behavior when two Cyclops safety cameras are in range.
Correct handling of track to route conversions that are completely off road.
Correct issues with simulator going off route.
Changes made from version 2.30 to 2.50:
Correct issue with mount detection logic when power is briefly interrupted.
Correct issue where SiRF chip cannot lock on after firmware update.
Correct issue when selecting a GPI point from the review map for a route.
Correct shutdown when displaying some banner messages in Italian/Spanish.
Correct issue with overlapping points in tour guide feature.
Correct issue with drawing the avoidances options page.
Use Locale setting to select American/European style traffic icons.
Changes made from version 2.20 to 2.30:
Corrected error in address searches for some cities using City Navigator Europe v9 maps
Corrected error that caused changes to be lost when editing the active route
Properly maintain point name when selecting route point and review on map and zoom
Corrected autozoom for off road navigation
Find user waypoints and custom POIs when diacritic values are present in names or search text
Corrected error in position propagation when entering a tunnel
Improved MPC map support
Decrease Proximity alert tone volume when connected to a Bluetooth helmet/headset
Re-enable Browse button in MP3 player when insert card
Corrected shutdown when select Extras from the phone or route planner menu if no extras are loaded
Corrected shutdown when searching for cities near another city
Corrected shutdown if active route recalculates while displaying user data pages
Corrected shutdown when selecting Auto as the service provider in FM traffic setup
Corrected rare shutdown when find traffic events along route
Changes made from version 2.10 to 2.20:
Correct display of diamonds that could occur in some translations in the route planner menu.
Correct issue that could cause vehicle to move sideways on the map.
Correct issue where Restore Defaults did not permanently save the Default Voice language.
Detlef
Beitragvon Detlef » 22.12.2007, 00:17
hihi... zwei Dumme ein Gedanke :wink:
Aber wir sind sicher beide froh, Heinz, dass dieser Tag nicht ohne eine gute Tat ausklingt!
Detlef
Beitragvon Heinz » 22.12.2007, 00:17
doppelt hält besser :lol:
Beitragvon Detlef » 22.12.2007, 00:18
jetzt lass mich bitte ausreden :evil: :lol:
Detlef
Beitragvon Heinz » 22.12.2007, 00:18
Detlef hat geschrieben:hihi... zwei Dumme ein Gedanke :wink:
:lol: :lol: :lol:
ich spiels jetzt mal drauf....
Beitragvon Heinz » 22.12.2007, 00:19
Detlef hat geschrieben:jetzt lass mich bitte ausreden :evil: :lol:
bittschön... :lol:
Beitragvon Vessi » 22.12.2007, 00:24
for our german friend's :wink:
übrigens, mein neuer zumo ist nach 7 tagen schon mausetot, :shock:
zurück zum erzeuger :cry:
Änderungen von Version 3,30 bis 3,80:
Fügen Sie Unterstützung für die afrikanischen Zeitzonen.
Fügen Sie Unterstützung für mehrere neue pre-recorded Stimmen.
Fügen Sie Unterstützung für die Entfernung in Metern, wenn eine britische Stimme ausgewählt wird (kann verlangen, aktualisiert Stimme).
Hinzugefügt Unterstützung für MAD Maps landschaftlich Routen.
Lassen Sie den Kompass zur Anzeige der Höhe 5-stellig.
Verbesserte Behandlung von Rundwege. Ermöglicht Eintrag auf alternative Punkt. Wird nicht verkünden Ankunft beim Start eine Route. (Alle Routen werden gelöscht, nachdem aktualisieren, kann aber re-importiert aus GPX-Dateien.)
Halten Sie die Karte Detail-Ebene, wenn Sie von den Haupt-Karte zu Karte blättern.
Bei der Überprüfung einer Tankstelle nach dem Drücken der Taste Kraftstoff von den Haupt-Karte, die Karte wird nun mittig auf ausgewählte Tankstelle, anstatt das Fahrzeug.
Ändern Optimale Nachbestellung so dass es nicht die letzte Punkt bei der Neuordnung.
Korrigieren Frage, wo Hintergrundbeleuchtung kann sich ändern, wenn Sie sich weiterhin auf die Hintergrundbeleuchtung einstellen Seite für einen bestimmten Zeitraum.
Korrigieren Frage, wo Hintergrundbeleuchtung kann sich aus, wenn vor Ort ist Polarkreises.
Korrigieren Frage, die manchmal dazu führen, dass Autobahnen werden beschriftet mit dem falschen Namen.
Korrigieren Problem, würde nicht zulassen, dass mehr als einen einzigen Punkt hinzugefügt werden einige Strecken.
Korrigieren, wenn die gleichen Fragen Karte geladen ist in zwei verschiedenen Regionen.
Korrigieren Problem bei der Suche nach Städten auf Basiskarte.
Korrigieren off road Übergänge in Spur zu routen, wenn es keine Karte Abdeckung.
Korrigieren Problem spielt Audible-Format 4 Bücher.
Korrigieren Entfernung für gemischte Routen aus MapSource
Korrigieren Frage, die den gesamten Datenverkehr verursacht Verzögerungen zu 1min bei der Verwendung von bestimmten Karten.
Korrigieren Problem verhindert, dass TrafficMaster Service von ordnungsgemäß auf den Namen des Geräts.
Korrigieren Problem verhindert, dass einige sehr große Track-Protokoll Aktivitäten aus korrekt archiviert werden.
Korrigieren Frage, wo Änderungen an einer Strecke wäre verloren, wenn Sie drücken und halten Sie die Schaltfläche "Zurück".
Korrigieren Problem verursacht, dass MP3's werden angehalten, für die Navigation bei Ankündigungen Navigation wurde auf off und einem vorher aufgenommenen Stimme ausgewählt wurde.
Beitragvon Detlef » 22.12.2007, 00:30
Hans, lass es, Computer sind dumm. Fuzzy-Logik geht anders :wink:
Detlef
Beitragvon Heinz » 22.12.2007, 00:33
...stimmt, jetzt verstehe ich noch weniger. :lol:
Tatsache ist, daß die Möglichkeit Autobahnen auszuschließen, verbessert worden sein soll, wobei ich bei richtiger Einstellung noch keine Probs hatte :D
Beitragvon Heinz » 22.12.2007, 01:48
...so...Update installiert, jetzt taucht unter Ausschlüsse ein neuer Menüpunkt "Autobahns" vermeiden auf.
...desweiteren ist es nicht unbedingt notwendig die Routen, Tracks usw vorher zu sichern, da sie nach erfolgtem Update über "einfügen" wieder eingespielt werden.
Beitragvon Georg » 22.12.2007, 01:51
Also tut sich was.
Beitragvon Heinz » 22.12.2007, 01:55
mal schaun. :lol:
Zurück zu Navigation - Gps
